- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Sony Walkman NWZ-A845 Buttons Confused
I own an NWZ-A845 and the search and scroll buttons are always mixed up.
UP is DOWN
DOWN does nothing
POWEROFF/OPTIONS does nothing
Sometimes after a file transfer, the configuration of these buttons will have changed, the most annoying of these is when the BACK button does not work, and I have to scroll through every track to get through albums.
I have tried the reset button many times, Any help greatly appreciated
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
this is a software problem... u sure u didnt catch any viruces lately?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi ChrisCanon,
thanks so much for the reply, nice to have some idea of what might be going on. My laptop suffers from viruses at least once/twice a year requiring a system restore. You think this has affected the walkmans software when I connected it?
If so, are you aware of any options (other than pressing reset switch) which I may have to resolve the issue?
I'm hoping the software isnt permanently corrupted????
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
why dont u get a anti virus... every computer suffers from viruces, i always use avira. and never had problems with anything
http://www.avira.com/en/avira-free-antivirus
its free antivirus and very good one. first clean ur laptop from viruces and then check the walkman and dont allow the antivirus to clean anything before u see what hes gonna clean. it might delete some operating software fromt eh walkman... i dont know where can i find software for u to reinstall it...if its not working after cleaning... if still the warranty is valuable just go and tell them u have software problem
