- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
Although my primary user account has "Allow Unknown sources" selected and I have no trouble installing apps there, I am unable to install the same apps from my secondary account. It says I need to change the setting but it's greyed out in the secondary account's settings and not switchable.
How do I fix this issue?
Thank you.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
With Android 5.0, there's an issue with enabling unknown sources in other user profiles but this was changed in Android 5.1. There's a discussion about it here with a response from Google: https://code.google.com/p/android/issues/detail?id=79728#c179
As the latest version available for Z4 Tablet at moment is Android 5.0 i'm afraid i don't have any solution for you. You could perhaps try to install the app using ADB as described in the thread at Google and see if that works.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
What kind of account is the secondary account? just tested this with a Z3 and you can select from unknown sources
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi uliwooly, thanks for your quick response.
It's a second standard user account, not a guest account. What's strange is that a message box appears telling me I need to change the setting, there is even a button in the message box that takes me to the correct setting page, but as I said, the "allow Unknown Sources" button there is greyed out.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
OK, did that, just the same unfortunately.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Guys,
I have just tested this on my own device, mine is greyed out also, this sounds like some variants will allow it and some will not.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Jake-SonyXperiaSupport@Andy147@uliwooly
I remember Rickard said a guest account or other than owner account cannot install apps.
@Rickard Could you shed some light?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
OK, so is there anything I can do to fix it?
