battery draining too fast in sony xperia z
vaibhav2701
Visitor
Dear sony users/support,
Battery draining issue is so critical that I have to always carry my charger with me need an plug socket near me
Most of the day if i use it for 1-2 hour than i have to think about if i have to take a long call.
if i have to disable all its functions and use only calling and sms than for what I have spent my money on sony
Sony must give me any solution for this major issue as I m unable to enjoy too long my sony xperia z
19 REPLIES 19
GeoffH
Enthusiast
kindly go to one of the existing threads here about battery and stamina - use the forum search
There is plenty of info - here are a few tips
remove all 3rd party task managers - battery apps - memory managers - antivirus
Live wallpapers will soak up battery - remove them
Turn off sync
Turn on stamina
Turn down screen brightness
take a look at battery usage and see what is using the most power
Things not to do without access to charger otherwise expect less than 6 hours battery - GPS - Watch Movie - Play High End games (2 hrs battery)
you get the idea - this is a smart phone as powerful as some laptops
vaibhav2701
Visitor
I upgraded to new firmware and getting lesss back up now after full charging
as i use it for 10 minutes battery % decreased fastly from 100% to 97%
Uliwooly
@vaibhav2701 STOP posting all over the forum, you already have answers
http://talk.sonymobile.com/thread/130237?start=0&tstart=0
http://talk.sonymobile.com/message/469846#469846
there's nothing wrong with your phone, if you believe there's something wrong and/or don't like the suggestions take your phone to a Sony repair center.
http://www.sonymobile.com/global-en/support/contact-us/
vaibhav2701
Visitor
Thank you
i think i have an taste of using nokia phones its my first time i switched to sony. I think u r right for me i will use it as it is. I m a working guy travelling all the time outstation thats why seeking any solution if it can help me more
i will surely not post anywhere dear
Thank u:-)
vaibhav2701
Visitor
Hi Dear,
I found my phone fine now for its battery power is stable now.
I found that this smartphone needs a smart use.
Thanx team for ur kind support:smileyhappy:
Uliwooly
anytime Slightly_smiling_Face
andrespinango
Visitor
Same happens to me, I connect the phone to the charger and still the battery is consumed if I use applications
Uliwooly
read the above info
Kahuna
Visitor
my "old" Z holds the charge maximum 1 day, my new *** (i dont call it :smileywink:) makes 3-4 days with 1 carge and self usage (all gimmicks like full enabled).
i think it is a software problem, maybe it gets better with 4.2
