- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
ever since Lollipop upgrade I see many issues with my Xperia Z2. But most of all that makes me mad is that the upgrade changed my notification sounds I had customized. not only that now I can not select my favorite sounds for specific notification. can only get sounds and ringtones that are on Lollipop by default. Can anyone help with this?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You should try settings-apps-all, tap on 3 dots and reset app preferences.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks but you discribed
@alexdon wrote:You should try settings-apps-all, tap on 3 dots and reset app preferences.
has nothing to do with sounds and ringtone for specific apps like text msg or incoming email.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thank I know I should be able too that is why I post here. I have a ringtone of my choice for phone. I CAN NOT assign a favorite rington for notification of incoming email or txt msg. ONLY sounds by Xperia no chois for my.
@uliwooly wrote:
You should be able to do so, you could use the music app, select song, menu, set as ringtone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I do recommend that you try the suggestion from alexdon. Sounds like you may have chosen the wrong sound picker app. After resetting app preferences, the phone will ask you which app to use to select ringtone/notification, here select "Sound picker".
But if this is not the cause it could also be that the sound you are trying to use is stored on the external SD card which may caause issues (we are investigating this). If so, try moving it to the internal storage.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It will only reset what app opens a specific file,it is not that difficult to set it up again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
