Chinese keyboard stopped after firmware upgraded today
SOLVED
gizmoha
Visitor
I connected my phone to computer this morning and the programme advised new firmware is available for upgrade,
so I accpeted all the terms and proceed the upgrading.
After the upgrade completed, I turned on my phone and wanted to msg my colleauges with whatsapp but
it said "Xperia Chinese Keyboard has stopped"
Some of my colleauges could not speak English and I need the chinese input method back!
what should I do with this?
is there anyway to downgrade the firmware or so?
1 ACCEPTED SOLUTION
Accepted Solutions
zeefung
Visitor
I had the same issue but I fixed by doing the following :
Go to settings -> Apps -> then swipe right till you see 'all apps' -> Look for Xperia Chinese Keyboard --> Then choose 'clear all data'
Afterwards, thr crash problem would be solved
10 REPLIES 10
zeefung
Visitor
I have just upated to 4.3, and have found that the English words spelling auto correction on the Xperia Chinese Keyboard on this new Android 4.3 update is not working.
In the settings for the Xperia Chinese keyboard, at "English text input settings -> Word suggestions", I have tried all three options, namely "I want to have my typos autocorrected" / "I never want to have any words or letters replaced" / "I don't want any help when writing, not even suggestions".
It looks like that the 1st and the 2nd option have completely the same effects. The 1st option doesn't "auto correct" my typos at all.
zeefung
Visitor
calissile
Visitor
Same problem here. Tried clearing cache, etc. Even did a factory reset but no luck. The international keyboard works flawlessly though.
gizmoha
Visitor
Problem sloved!!! THANKS!!!!
zeefung
Visitor
Would someone from Sony confirm that this is a bug in the firmware update for Android 4.3 for Z Ultra?
Andrew_Lee
Visitor
The solution provided didn't help. Even for my reply which I spent much effort to help. Can Sony escalated this to next level of support please?
Andrew_Lee
Visitor
The solution provided didn't help. Even for my reply I am posting here which I spent much effort to type. Can Sony escalated this to next level of support please?
JiaNs
Visitor
Hi zeefung,
This happened to me and my frd too. Was it finally resolved at your end? Else, appreciate if Sony Support can advise on how to troubleshoot.
Thanks.
tristaism
Visitor
I've the same problem even I clear data for chinese keyboard, but the problem solved while I clear data for xperia keyboard too.thanks.
