How get auto-answer ?
SOLVED
profile.country.en_GB.title
dweaver1
Member
I have tried several apps, but all crash.....
Please can anyone recommend one ?
1 ACCEPTED SOLUTION
Accepted Solutions
dweaver1
Member
No wonder I can't find an app that works - from 'lollipop' this action is not permitted.....
7 REPLIES 7
Uliwooly
@Dean_Weaver
keep looking for other apps, and are you referring to calls or messages?
dweaver1
Member
Calls - do xperias handle calls differently, or is my experience with crashing apps just unfortunate...
Uliwooly
@Dean_Weaver
You should contact the app developer regarding this, also if you have taskillers, antivirus that might be the cause
dweaver1
Member
I run neither of these - guess I'll get a phone with it next time...
profile.country.RO.title
_alexdon_
@Dean_Weaver There is smart call handling, not really auto answer, it needs a little moving first.
alexdon
dweaver1
Member
I have tried half-a-dozen apps - they either do nothing or crash...
Please can anyone recommend one that works ?
dweaver1
Member
