Light sensor not working after lollipop update
daltzi
I run the diagnostic test on my device after the update and light sensor failed.it worked normally with kit Kat 4.4.4! Another bug? Can anyone help?
27 ANTWORTEN 27
Hamed-Sa
I can't confirm if light sensors fail after last update of lollipop or not.
But in any case..  Sony has to check deeply and inform the users for final solution.
Not just trying lot of things for nothing.
Uliwooly
@Hamed-Sa
You should get your phone inspected, and not assume that it's affecting all Xperia Z3 Dual users.
WillberG
I too have doubts about my light sensor. I have done a service test and get:
Ambient Light Sensor
Value:2.0
What does this mean, please?
emk
@willberg put a flash light over the sensor and the value would jump up which means the light is detected
WillberG
So it does, thank you!
And I can confirm that the screen brightness does change automatically, just slower and more subtly than I was expecting. Oh well, I can live with that.
IsraelNobrega
Same here...it was the app. Thanks, SomeQuickAdvice!
Wasif1122
My xperia z3 light sensor not working and
When I full screen brightness the screen blink 😔
What I do.? Any suggestion.?
Jafolla
I can also confirm that uninstalling diagnostics sorted it...
