Solved! Go to Solution.
When using screen mirroring, do not cover the Wi-Fi antenna area of your device. |
Your TV must support screen mirroring based on Wi-Fi CERTIFIED Miracast™ for the functionality described above to work. |
Your TV must support screen mirroring based on Wi-Fi CERTIFIED Miracast™ for the functionality described above to work. If your TV does not support screen mirroring, you may need to purchase a wireless display adapter separately. |
When using screen mirroring, the image quality may sometimes be negatively impacted if there is interference from other Wi-Fi® networks. |
Excellent
