Power button plays ringtone
SOLVED
suzid
Visitor
Hi,
I bought the Z5 yesterday and if I hold down the power button, my ringtone starts playing.  If I hold it down again, it will start playing again over the other ringtone and my only option is to use the rocker button to silence it but when I turn the volume back up it will still be playing so my only option to stop it is to restart.  This is everytime I hold down the power button.
If anyone could shed any light I would be so grateful!
Thanks in advance.
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.RO.title
_alexdon_
Go to settings-accesibility and see if accesibility shortcut is enabled.
alexdon
6 REPLIES 6
_alexdon_
alexdon
Christofer
Champion
Hi @suzid,
That sounds strange.
Alexdon could be on to something so check the Accessibility shortcut setting and see if that is enabled.
If not, could you check if this still happens if you put your phone into safe mode?
suzid
Visitor
Thank you so much Alexdon, problem solved.
Thank you too Christofer!
_alexdon_
Anytime. Enjoy your device.
alexdon
Christofer
Champion
I'm glad to hear that @suzid, happy new year! Slightly_smiling_Face
Good catch @alexdon!
_alexdon_
Thanks @Christofer man!
alexdon
