In the last week my Xperia Z keeps restarting, the volume up doesn't work and my fingerprint option is missing....... What's going on?
There is no damage to my phone and no dodgy apps installed.
How can I sort this?
firstly, try to boot your phone to safe mode
. observe your phone for recurrence of the problems.
if the problems doesn't show up . it means it might be a software problem.
try to perform software repair using Xperia Companion ..
FYI: Xperia Z , doesn't support fingerprint options
Hi @Prudz,
As @nolramlb mentioned, Xperia Z do not have a fingerprint sensor and thus no fingerprint manager. Could it possibly be another Xperia device than a Xperia Z? If so, please return with themodel number of your phone. You can find the model number of your phone by going to Settings > System/about phone.
Please return with this information and I will do my best to assist you!
