Sony Xperia Z1 camara problem
SOLVED
Abhay_Wakchaure
Visitor
I have purchased Z1 just 15 days ago, and update it to kitkat 4.4 yesterday. But scene and HDR option is disabled and not working. I also tried repair by SUS but not helped. Please help.
1 ACCEPTED SOLUTION
Accepted Solutions
manjuboyz
Contributor
Hi guys
 if not worked then please carry your phone to the nearest Sony Centre ,since it is new phone they would be able to get it fixed
Manjuboyz Slightly_smiling_Face
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks Slightly_smiling_Face
7 REPLIES 7
angello011
Visitor
same for me in manual mode
manjuboyz
Contributor
Hi
>I hope you tried reparing the phone using high speed Broadband(not wifi) , it happened my once using WIfi after repairing using Broad band it fixed my phone issue
>if you are using Broadband then try USB port which is present at the back of the computer(if desktop) or if you have different computer then try to repair phone using that
>check if you have installed "Chrome" on your phone, remove it first then upgrade it , it might do a trick
NOTE:
angello011
Visitor
i just tried to repair my phone, and the HDR option is stil in grey????
any other idea?
Abhay_Wakchaure
Visitor
Thanks for reply. It's not worked. If I reduces the megapixels to 8, scene and HDR option work.
manjuboyz
Contributor
Hi guys
NOTE:
somedayshabby
Visitor
Why isnt there movie studio on z1? I can't edit videos.
rosek-mj
Visitor
I need help in my xperia z1 me camera is failing much when Opening the camera app screen stays Black and i have to restart the phone and Still continúes to fail
