- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi, I have an issue with notifications on my z3. Every notification works except with messages. When i receive a message i have no notification. Have checked settings and they are all fine. Regards Steve Johnson
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ok, try this: settings-apps-all, tap on 3 dots and reset app preferences. This will reset some of your apps set up to open certain files or links but you can set them up again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Messages from default app or those that require an internet connection?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have checked and double checked all settings. Deleted loads of Apps,but not all. I get notifications for everything elsebut not messages!!!!!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just text messages.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Safe mode is different, it will only load default apps so you can check if there is an app acting up and creating the problem you experience.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Press power button, a menu will pop up. Press longer on turn off and reboot in safe mode should come up.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
