Spell check disabled
ceciliabramucci
Visitor
A seguito di reset del telefono non riesco piu ad attivarlo. Le relative voci delle impostazioni sono grigio chiaro non selezionabili. Grazie.
fter resetting the phone I can no longer activate it. The related setting items are light gray not selectable. Thank you.
gt
1 REPLY 1
Uliwooly
@ceciliabramucci911
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Are you referring to
settings > Language & input > Spell checker
does it say No apps with spell checkers installed ?
After resetting the phone I can no longer activate it. The related setting items are light gray not selectable. Thank you.
