Xperia Z won't charge unless completely drained.
mashare
Visitor
Few days ago I noticed that my Xperia Z won't charge. I tried force restarting, charging when turned off, nothing works. The cord and power outlet is fine. I decided to slept on it, leaving my phone on the charger and woke up the next day with my phone fully charged. I tried this yesterday and it works like that as well. however I cannot connect my phone to the computer  (the computer says your device malfunctioned or something like that) or charge it when it's not drained. Any idea what's going on?
16 REPLIES 16
sarahric16
Visitor
I have this exact same problem.  Not charging from a wall plug unless completely drained. Not recognised by computer.  Have replaced the battery and still no good.
Idunno
Visitor
I have the same issue
dehme999
Visitor
i have the same problem!!
this is totally unacceptable from sony!
what should i do now to solve this problem !!??
Uliwooly
@dehme999
check the suggestions on the first page, perhaps you need a brand new battery
dehme999
Visitor
the battery  is fine am sure
if i do factory reset , would that help ?
Navsail
Visitor
I having same issue.
If wish to charge phone .have to first completely drain it. By repeated start and shut down.
When has zero charge,  able to charge it.
Is difficult to manage the phone.
Strange no one could come up with a solution to this problem being faced.
cagdason
Visitor
I still have this problem was thinking to use the phone for a project changed the battery with no luck stiil need to completely drain before charge.
Any body had a solution?
