I have z1 color black. But I planning to buy xperia z2 color white. But i see some video in YouTube it say it easily stain the color white?? It is true?
Solved! Go to Solution.
I concur as well. I've used a lot of white Xperia, but the Z2 version tends to stain easily. Specifically the white frame. It's design to be rough instead of smooth, as a result it tend to stain easily. Even the putting the phone inside an empty pocket in my pants cause the colour of the cloth to be absorbed on the white frame. And it doesn't go away after using soap or even alcohol. =x
Enough to say it's no longer white.
@nacionmclen@gmail.com wrote:I have z1 color black. But I planning to buy xperia z2 color white. But i see some video in YouTube it say it easily stain the color white?? It is true?
It definitely true. A little wash should remove the stain. The only reason this happens is because of the injection molding used around the aluminium frame.
It happens on all the devices but it's not noticeable on the darker colours.
Hmm, but it say its only for color white. It not happen in in black and purple. Only white easily stain the color when you always put in out pocket always. If is true its disappointing. 😞 so maybe i prefer again in black color!!
I would recommend you get the black variant. It looks better than the others in my opinion.
The stain does still occur, only you can't see it. But it's true that the white variant stains much more easily than the other two.
It's true.. The z2 body frame easy to get dirty. I will use eraser to rub it sometimes..
USE A isopropyl alcohol WIPES TO WIPE OFF THE STAIN
