Z3 compact back and home button not working after recent update
SOLVED
Haystax
Visitor
My back and home button not working now after. 5. 1.1 update.
1 ACCEPTED SOLUTION
Accepted Solutions
CameronT
Champion
@Haystax,
You might be dealing with a faulty screen. I recommend you contact your local support team with the link in my signature to arrange a repair.
158 REPLIES 158
Uliwooly
@Haystax
I doubt that its related to the latest update, check this
settings > about phone > diagnostics > test > test touchscreen
CameronT
Champion
Hi @Haystax,
Welcome to the community.
It does seem odd that it would happen right after the update. It's possible the update didn't install correctly. I recommend running a software repair.
Haystax
Visitor
Done test done repair via pcc,still not working. Was working fine for a couple of days after update,then decided to not work. Can work on glove mode,but makes screen very sensitive. Is there a fix for this,not happy now,only had gone for a few days.
Uliwooly
@Haystax
could you try a different computer?
CameronT
Champion
@Haystax,
Do you see any physical damage on the screen, such as hairline cracks?
Haystax
Visitor
No cracks on screen....Not even hairline ones..
CameronT
Champion
@Haystax,
SMB-76
Visitor
Hi there!I have the same problem now with my z3 compact.. at first the notification drop down was no longer responding..and now the back button also not responding. I thinkthe problem is in between the interaction software to hardware. Since this only happens after I updated to Lollipop. Sony Mobile should do some pactch or global update for this.
Akk1
Visitor
@SBM visitor
Even I am facing same problem with my Xperia z3 compact,its happening after the update is 6.0.1
