Z3 Compact stuck at 7% battery.
SOLVED
yoganerdYVR
Visitor
I was getting constant vibrating warnings that my battery was low at 8%.  I had to put the phone in DoNotDisturb.  Battery dropped to 7% while plugged in so I turned it off.  Waited an hour and it's still at 7%, screen keeps flashing the SONY XPERIA logo, then off, in an 8 second loop, then displays a charge indicater every 10 or so loops (haven't counted).
Anyone have suggestions?  I can't pull the batter on this one.
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
@yoganerdYVR
Connect the phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 1 or 2 hours > check again.
5 REPLIES 5
Uliwooly
@yoganerdYVR
John-BR
Visitor
Hi YoganerdYVR
Welcome to the community.
Here's how to run the repair on PC Companion:
  1. Install and open PC Companion then select Support Zone.
  2. Phone Software Update.
  3. Start.
  4. Repair Phone
  5. Continue
  6. Accept data removal
  7. Next
  8. Wait for prepare
  9. Select Phone
  10. Follow the connection steps
And Bridge for Mac:
  1. Launch Bridge for MAC without the handset connected.
  2. On the Main Window select "Xperia > Repair Xperia Device".
  3. Ensure the phone is charged and select "Ok" in the following window.
  4. Select Continue on the following page.
  5. Wait until the initialising step is finished the continue as below.
6 . Select your model of phone from the list that appears
  1. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
yoganerdYVR
Visitor
That worked.
Uliwooly
@yoganerdYVR
Excellent Winking_Face
yoganerdYVR
Visitor
Same problem is back again and it's not going away after a soft reset like it did last time.
