Please allow Xperia 1 VI to utilise WiFi 6e and 7 in Australia and New Zealand
FrederickZhUK
I recently purchased a TP-Link RE655BE AP, which supports WiFi 6GHz with both WiFi 6e and 7 protocols. After spending a little time to set it up, I was excited to finally embrace the next-gen WiFi on my 1 VI.
Unfortunately however, my phone wasn't able to pick up the 6GHz-only SSID; although I could use the MLO one (2.4/5/6GHz 802.11b/g/n/ac/ax/be), it just stayed on 5GHz with WiFi 6.
Upon further investigation, I suspect that WiFi 6e and 7 are disabled in Australia as AU is missing from the lists in /oem/etc/customization/config.prop:
ro.vendor.sony.wlan.6e_cc_list=HK,JP,AT,BE,BG,HR,CY,CZ,DK,EE,FI,FR,DE,GR,HU,IE,IT,LV,LI,LT,LU,MT,NL,NO,PL,PT,RO,SK,SI,ES,SE,GB,CH,IS,MY,TH,TW,SG,MO
ro.vendor.sony.wlan.11be_cc_list=HK,JP,AT,BE,BG,HR,CY,CZ,DK,EE,FI,FR,DE,GR,HU,IE,IT,LV,LI,LT,LU,MT,NL,NO,PL,PT,RO,SK,SI,ES,SE,GB,CH,IS,TH,TW,SG,US,MO
According to Wikipedia, Australia allows the same channels as those in UK, and New Zealand allows the same ones as those in Japan. Since both UK and Japan are in the lists already, I hope it's not too much trouble to add AU and NZ too. Could the Xperia developers kindly consider? Thank you!
Tags (3)
15 ANTWORTEN 15
FrederickZhUK
Hi @MaggieGreene, I'm afraid that didn't help. Could you please file an internal ticket to track this issue? Thank you!
MaggieGreene
Community Team
Hi @FrederickZhUK, try the steps in this link: https://www.sony.co.uk/electronics/support/mobile-phones-tablets-mobile-phones/articles/00292437 If the issue remains after these steps, you can contact Sony AU: https://www.sony.com.au/ Or Sony NZ: https://www.sony.co.nz/ they'll be able to assist you further.
FrederickZhUK
Upgraded to 69.1.A.2.189. Still no change unfortunately.
TheGOAT
Community Team
Hi @FrederickZhUK In that case you will need to report this to Sony technical team.
FrederickZhUK
@TheGOAT Thanks for the pointer! May I know how I can get in touch with the technical team?
TheGOAT
Community Team
@FrederickZhUK Here you go I checked, and this is the UK contacting link: https://services.sony.co.uk/supportmvc/en/contact/
