Hallo Sony,
Hi Sony,
I'm a professional dutch cinematographer, and I want to help you to serve the videographer/hdslr market (currently owned by canon and friends). I like my A77 but in order for me and other videographers to 'love' the A77, there are some weird loose ends.
I have made a wishlist for the next firmware update. Some of these issues might be easy to fix, some might be hard to fix. Please try. To all the forum members, feel free to post wishlists of your own!
1) Focus magnification for video
2) Manual Audio Control
3) PAL/NTSC switch for flexibility and traveling users
4) Shutter button should be the record button while in videomode
5) Live on-screen histogram in videomode
6) Autofocus with shutter priority, we need that 180 shutter for a film look
7) Autofocus with aperture priority so we can shoot with autofocus on f2.8 and below
😎 Auto iso in manual mode
9) Higher ISO limitation in videomode (3200 >)
10) If SteadyShot is turned off for video, allow use of a larger portion of the sensor to eliminate the extra crop video mode receives. Thus making shooting video in photomodes easier to compose, possibly improving video quality further and taking better advantage of wide angle lenses.
11) Clean HDMI video out
12) Control delays fixed
13) Double-bitrate mode (48mbit/sec) if possible.
14) A “flat”, less contrasty picture profile for Color Correction. (such as cinestyle for the Canons)
13) Tethered shooting
14) Allow peaking mode to be turned on/off via an assigned button (the ‘?’ button should be good)
Thanks for listening. Good luck Sony!
Best regards,
Jochem
Message was edited by: Jochemdevet
Message was edited by: Jochemdevet (translation for this forum)
Gelöst! Gehe zu Lösung.
Beste Jochemdevet,
Welkom op het Sony Forum.
Waarschijnlijk heeft u de opmerkingen van de moderator gezien wat betreft de Nederlandse taal die gebruikt wordt op dit forum.
Gezien uw forum nickname ga ik er van uit dat u Nederlands spreekt.
Bedankt voor uw reactie en suggesties.
Alhoewel ik niets kan zeggen over eventueel komende updates, aanpassingen, o.i.d. kijkt Sony natuurlijk naar de ervaringen van zijn klanten teneinde daarvan lering te trekken.
Zo ook met uw opmerkingen, resp bevindingen.
Ik wens u verder veel succes met uw werk en het gebruik van de A77 camera.
Met vriendelijke groet,
Hans_Klis
Sony medewerker
Hello Jochemdevet,
Welcome to the Dutch Sony forums. Please note that this is a Dutch language forum and it will be easier for users to engage you if you post your message in Dutch. For ideas in the English language please access the English forums by clicking the language selection option at the top right of your screen, next to the Sony logo.
Kind regards,
Tycho
Moderator
Hallo Jochemdevet,
Welkom op de Nederlandstalige Sony forums. Dit is een Nederlandstalig forum en het is makkelijker voor de gebruikers om je te helpen als je je berichten in het Nederlands plaatst. Voor suggesties in het Engels kun je terecht op de Engelse forums, klik hiervoor op de taal selectie knop rechts bovenaan je scherm naast het Sony logo.
Tycho
Moderator
Ik denk niet dat het nodig is de "wishlist" te vertalen, maar ik kan ze wel onderschrijven.
Ik begrijp niet dat tethered shooting onmogelijk is met dit toestel. Met de a700 kon het wel.
Wordt hier aan gewerkt?
Beste Jochemdevet,
Hans_Klis
Sony medewerker
Beste Hans,
Zodra u wel iets kunt zeggen over het oplossen van deze punten dan hoor ik het graag.
Bedankt voor het antwoord.
Jochem
Beste Tycho,
Aangezien de gemiddelde nederlander erg goed engels spreekt en de meesten punten veel engelse termen bevatten heb ik het initiele bericht in het engels gepost. Maar om me netjes aan jullie richtlijnen te houden heb ik het bericht bewerkt en een nederlandse vertaling toegevoegd.
Jochem
Ik sluit me hierop aan, er missen toch wel een aantal belangrijke functies!!
Verder zou ik graag willen dat de knop om snel een video opname te starten kan worden uitgeschakeld!
Het is me al meerdere keren overkomen dat ik de knop per ongeluk indruk bij het uitklappen van het LCD scherm, gewoonlijk pak je de rechterbovenkant vast en dat zit heel dicht bij de knop.
Het lijkt me niet zo'n groot issue om dat via het menu te kunnen regelen ?
Ook een afstandsbediening om VIDEO opname te starten zou zeer welkom zijn, nu start de opname bijna standaard met een lichte trilling, zeker bij opname met langere telelens.
Message was edited by: japostm94
ik sluit me volledig aan bij deze lijst!
Het is erg belangrijk om effectief features to te voegen aan bestaande toestellen.
Niemand kijkt enaar en er komt toch geen oplossing. Wel verkopen maar geen opvolging. Is bijna overal zo.
