3D gone from my 3D TV?
profile.country.DK.title
MattK91
Hello all.
I have a problem with my 2015 KDL43W805C.
The 3D option from the Action Menu is just - gone. It only appears when on youtube which is not that useful to me.
I used to be able to rip my 3D blurays, put it on an external harddrive and watch it with VLC. But now the 3D option will not appear in VLC or any other video app. Not even Sony's own Video app.
I got an update 30 days ago and installed it but now is the first time since that update I wan't to watch a 3D movie so I can't say for sure if the update has something to do with it.
Do any of you have a suggestion or a fix?
Thanks
1 ANTWORT 1
Anonymous
Nicht anwendbar
Hi there
Unfortunately this is a known issue with no fix as of yet. See :
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2126443#M41214
Cheers
