- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Amazon Fire TV Cube connection
Simple question - please pardon my ignorance -
when connecting HDMI cable, which port do you use on the Bravia TV ? But hazy but is it the ARC socket (3) or should it be one of the others ?
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey OldGrumppy, usually I use the ARC to get the best experience.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Many thanks, Hannah - I'll try when it arrived ( just trying to get myself organised for when it arrived later in the week )
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
"arrives" NOT "arrived" ( damn predictive txt !! )
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That depends on the TV or the device that you are using. The ARC is usually for sound systems and soundbars.You can find more info about the ARC here. Also to get the best 4K image, you will need to set the TV to enhanced mode (depending on the model). What is the model number of the TV?
Regards,
Gladio
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
My TV is : KD. 43XG8196
Thanks for showing an interest
Regards, OldGrummpy
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi OldGrumppy ,
You can set the TV to enhanced mode for better experience following: ( Settings - Watching TV - External inputs - HDMI signal format - Enhanced format )
Hope it helps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@HannahEd01 @OldGrumppy @Pentium_Gladio
I’m with Pentium Gladio here.
Any of the HDMI ports on a TV can accept video and audio from a Firecube, with sometimes one or two of the ports being enhanced to be better than the others.
But if there is more than one such port, then you are wasting the ARC capability if you use the one and only ARC port for the Firecube, as the Firecube won’t do anything with audio returned from the TV (ARC stands for Audio Return Channel), whereas a soundbar or AV receiver could.
My favourite bedtime reading is a Sony product manual…
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
royabrown2, no
Thank you for the information - very informative and practical.
I really do appreciate all who have taken the trouble to advise.
My regards
OldGrummpy
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Has this answered your question/solved it for you? If so, it'd be really helpful to others with the same question if you mark the solution.
And if not, do let us know so that we can help.
- JD
