Channel Editor Not Working?
pixlrik
Explorateur
I recently purchased the Bravia 8II and have exported my channel list to a USB memory stick for editing on my PC. When I select the sdb.xml file on the memory stick, the program states that no channels were found. Any ideas?
9 RÉPONSES 9
profile.country.FI.title
TTTMMMAAA
Explorateur
I have exactly same issue with A95l +mobile channel editor app !!!
Sony support answered this Bull...t :
"...We have received the answer to your question from our technicians.
In this case, channel sorting has been disabled due to country-specific regulations and the rule to disable sorting applies to all operators. In the case of Finland, it is not a single operator that has requested this, but all of them.
On some older Sony televisions, channel sorting may be possible because this requirement had not yet been introduced. Similar restrictions can also be found in, for example, Sweden.
SO WHAT THE F..k!!! ???
Sony is lying!!! because digita.fi (finnish broadcast main unit) has never heard of such a thing.
And they (Sony) are not interested in it at all!!!
pixlrik
Explorateur
The program doesn't work at all, but the Bravia phone app does but with basic functionality, and it doesn't let you edit your favourites which is a massive drawback. Just the channels as they have been tuned in. Hopefully this can be addressed in an update.
LightFoot
Spécialiste
Hi @pixlrik   Have you made Sony Support aware, that there is a problem?
pixlrik
Explorateur
Hi, I did not think of contacting them to inform them of this, as with most companies they usually fob you off and the issue is never resolved. I was hoping someone had knowledge of a workaround that would work. I will try to contact the support team now and see what they say.
Grecian2000
Nouveau
After many hours head scratching, managed to open file using text editor on Mac. Managed to modify and save changes, use 'Save As'.  Didn't reload as I use a Freesat STB as TV EPG no good.
daveyh64
Passionné
Having looked at the support page for your TV and the downloads section, there is only a downloadable version of the channel editor for mobile devices, there is no longer a link for the channel editor for Macs or PC.
Click on the link below,
https://www.sony.co.uk/electronics/support/televisions-projectors-oled-tvs-android-/k-55xr8m2/downlo...
That makes me wonder if Sony are no longer supporting the 'computer' version with its newer TVs.
Were you perhaps using the channel editor app on your PC with a previous Sony TV and expecting the app
to work with your new Bravia 8 II.
pixlrik
Explorateur
The Bravia app for mobile phones works with the Bravia 8 II but the app itself only has basic functionality. It doesn't allow you to view or edit your favourites list, and that is what I use as I have channels from different sources all in one list for ease of browsing. If the app was updated to include the viewing and editing of Favourite Channels then there would be no issue. I have contacted Sony Support and am awaiting a response from them about this.
TTTMMMAAA
Explorateur
Now the behavior of Sony support is ridiculous.They asked to send a screenshot of the TV channel signal information??? What the h..l does that have to do with the TV channel editor? Well I sent it.
Still, they claim it's the cable TV operator's fault, which is definitely not true.!!!
I also noticed that the A95L doesn't output dolby digital+ audio to my yamaha rx-A2a avr via ARC
My old KD55A85 did not have that problem.
This overrated "top class" A95L is totally piece of crap.
Fortunately i can return it and I will switch to another brand.Especially because of Sony's arrogance and lies.
profile.country.RO.title
mysonyhdrsr1eid
Nouveau
La o întrebare anterioară într-o altă conversație, Sony AI Support mi-a răspuns că:
”În prezent, fișierul „sdb.xml” de pe BRAVIA 8 II nu este compatibil cu aplicația Sony Channel Editor pe PC, deci organizarea listelor trebuie făcută direct din TV.”
Și totuși, la butonul ”Produse și categorii aplicabile” Televizoare, monitoare și proiectoare scri că - Android TV / Google TV (BRAVIA OLED).
K-55XR8M2 / BRAVIA 8 II este un televizor OLED.
Deci, de ce fișierul „sdb.xml” de pe BRAVIA 8 II nu este compatibil cu aplicația Sony Channel Editor pe PC ?
Răspuns Sony AI Support:
”Aveți dreptate că BRAVIA 8 II este OLED și apare în categoria Android TV / Google TV, însă:
1. BRAVIA 8 II nu folosește fluxul clasic „sdb.xml” pentru editare pe PC
Pe această generație, Sony a schimbat modul recomandat de organizare a canalelor:
- Direct din TV:
Settings → Channels & Inputs → Channels → Channel list edit
- De pe mobil:
Settings → Channels & Inputs → Channels → Channel list edit from mobile device
(se urmează instrucțiunile de pe ecran, prin aplicație pe smartphone).
2. De ce apare totuși în listă la Channel Editor
Pagina aplicației Sony Channel Editor este generală pentru mai multe familii Android TV / Google TV, inclusiv modele OLED mai vechi care foloseau structura „sdb.xml” compatibilă.
La BRAVIA 8 II, implementarea actuală a listei de canale este diferită, astfel că:
- fișierul exportat de TV nu are structura așteptată de aplicația de PC;
- rezultatul este că Sony Channel Editor pe PC nu poate lucra corect cu fișierul acestui model, chiar dacă linia de produs (BRAVIA OLED) apare la „Produse și categorii aplicabile”.
Pe scurt, compatibilitatea este la nivel de platformă generală, dar nu toată generația folosește exact același format de fișiere.
Pentru BRAVIA 8 II, soluțiile suportate oficial sunt:
- editare direct pe TV;
- editare de pe smartphone prin „Channel list edit from mobile device”.
”Chiar la acest model de televizor, vârf de gamă 2025, Sony a ales să mute prost!
Mulți posesori al acestui model se plâng de inutilitatea aplicației!
Editarea Favorite 1, Favorite 2, Favorite 3, Favorite 4, este imposibilă cu telecomanda.
Să ai toate Favoritele la grămadă nu este o soluție!
Astfel, pot concluziona că: evoluția nu înseamnă neapărat și progres!
Și asta în cazul lui Sony!”
”Se înțelege perfect frustrarea, mai ales la un model de această clasă.
La BRAVIA 8 II, comportamentul listelor Favorite 1–4 și limitările aplicației Sony Channel Editor pe PC sunt rezultatul felului în care a fost gândită noua platformă de canale (inclusiv integrarea cu editarea de pe mobil), nu al unei probleme punctuale cu aparatul dvs.
Din păcate, în acest moment:
- canalele favorite sunt afișate într‑un singur flux combinat,
- nu există, oficial, un mod de a gestiona separat Favorite 1/2/3/4 din aplicația de PC,
- iar din telecomandă, organizarea este mai greoaie și mai restrictivă decât pe generațiile anterioare.
Observațiile de genul celui menționat (utilitatea redusă a aplicației în combinație cu acest model, dorința de a avea favorite separate, mai ușor de gestionat) sunt exact tipul de feedback care se transmite intern către echipele de produs și software.
Este justificată concluzia dvs. că, din perspectiva utilizatorului care își organizează în detaliu canalele, această „evoluție” nu se simte ca un progres.
***Moștenirea bazată pe PC Editor de canale Sony este într-adevăr incompatibil cu sistemul de operare modern Google TV/Android folosit pe Sony BRAVIA 8 OLED (55XR8M2).
***Televizoarele Sony mai noi nu mai suportă exporturi USB pentru lista de canale (fișierul) pe software-ul lor de calculator (sdb.xml)
