Делитесь своим опытом!
1. TV goes off with right colour temperature Expert 1
I turn it off , and, after 8 minutes I turn on the TV... It's gone, it's all bluish.
I have to manually change it in the menu or change to:
Another HDMI
TV
App.
Did two factory resets and I won't do no more!
This is incredible. It's a basic thing. The TV has to retain its color
Configuration. I've never seen anything like this in my entire life!
2. The red optical light of the toslink connector for audio on the back of the TV doesn't go off.
I am just wondering if this nice piece of engineering is always online...
Can anyone confirm to me that, after 8 minutes off, the red toslink light goes off on the back of the TV, please?
Thank you.
this is bad, you should not do that. you gonna hurt your tv...
who says this?? Do you have a link?
i do unplug my devices over 10 years now, no probs at all.
as i said it´s only a work around... main problem(= doesn´t save picture colour temp) still is unsolved!
i´m 100% with you - this work around is good for a quick laugh
and this
sony has to solve that.
Make SONY Great Again
Maybe a more convenient workaround would be to switch to the home menu before turning the tv off?
Now, when turning on the TV, I had the problem that picture mode was set to Standard instead of Cinema Home... so annoyed by this TV...
so let me ask the question 🙂
Did Sony solved the colour temp problem with the update
Release Date
for the w80xc series??
i? hesitate
