Is it wise to perform a Factory reset BEFORE applying a Firmware Update?
profile.country.GR.title
MiCal1967
Vielschreiber
This means Automatic Update must be disabled.
3 ANTWORTEN 3
profile.country.IT.title
rooobb
This is overkilling :slight_smile:
Do it only after and only if you have problems....
MiCal1967
Vielschreiber
Thanks rooobb.
I think that there is no one without problems.:smileycry:
Sony owners are champions on that. There are about 200.000 inside this community:smileywin:
Anonymous
Nicht anwendbar
On a side note, it seems that updating via the USB method seems to go quicker and smoother than the OTA method.
