- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have a question, is built in chromecast able to cast video in UHD "4K" resolution?
When I cast pictures or video from mobile it looks like casting only FULL HD.
I use HOME app from google on my mobile Galaxy S8.
Casting video is not smooth.
I found answer already - yes, UHD cast is possible.
Problem with smooth wideo solved by reboot both devices.
Is there a chance to remove apps from app panel?
I switched off non used apps, but few of them are still in the application list.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi mitorek28,
You can only remove the app only if it's not a pre-installed app, you can delete it from the app store. You can't remove or hide the pre-installed apps.
Cheers,
Almou_10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi mitorek28,
Welcome to the Sony Community.
I'm looking into this for you and will get back to you soon.
Cheers,
Sean Mc
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Almou_10
Thank you for your answer.
