KD55X8509C, Issues with 3D.picture blanking out while watching a movie via 3D,BD.disc.
drewatthemovies
Tags (1)
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
drewatthemovies
Hello again and thanks for responding to my tech issue. Problem was with my TV.dynamics settings for the HDMI connections.Set for "full" instead of "auto"solved the problem!.3D is no longer :grin:balscked out during the movies!.
5 ANTWORTEN 5
Pascale_F
Moderator
Hi Drew,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime though, maybe someone else in the community might have some ideas?
Thanks,
Pascale
Tenneen9000
Hi Drew,
That's disconcerting! Do you experience this on a certain disc? Also, have you tried refreshing the TV by unplugging the external devices and the power cord for at least 1 minute?
Thanks,
Mustafa
drewatthemovies
Hello and thanks for replying, the issue with picture-blanking is with any 3D. disc.While the picture is blank the sound carries on as normal.After about 30-45 seconds,the picture returns and 3D.is fine again.It varies but it can happen about 4-5 times during a movie.          Andrew (UK).
The_Black_Rose
Spezialist
Hi Andrew,
Have you tried performing soft reset to the TV using the steps here: https://bit.ly/2DVxVVV? Also, this may be due to the software version being outdated. Can you make sure that the software of the TV is up to date as explained here: https://bit.ly/2Tvp1D3?
Cheers,
The_Black_Rose
drewatthemovies
