KD55XD8002 TV
michaelross
KD55XD8002 TV
Hello, my Sony TV has started a loud Ladies voice whenever  I input any instructions from the remote ie when the volume is changed up or down a loud voice says speaker volume a certain number depending on how high or low I have the volume set at,also when searching for apps or programs, there’s a running commentary on what has been selected,it’s driving me mad.I’ve searched through the various to menus but can’t find anything to switch the voice over off,
any ideas anyone? thanks, Michael.
5 ANTWORTEN 5
LightFoot
Spezialist
Hi @michaelross
It will be something in your accessibility options. On the latest TVs it is called TalkBack but may be something different on your TV.
This is an American article, so I don’t know if it helps. https://www.sony.com/electronics/support/articles/00233448
Accessibility options maybe under System.
michaelross
Hello, thanks for the reply.I will have another look at the TV menus again and also the link you sent me thanks,the tv is a few years old now, it strange that it has happened suddenly,
cheers, Michael.
michaelross
Hello again,I have tried the link that you have sent me and unfortunately there is no accessibility option on this tv it is about 8 years old now.There doesn’t seem to be anything else in the settings menu that relates voice narration,
thanks, Michael.
LightFoot
Spezialist
Hi @michaelross
All Sony TVs have accessibility settings, did you look under System?
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-55xd8005/artic...
You may have to reach out to Sony Support
michaelross
Hello,I finally managed to get into the accessibility menu and have turned the voice narrative off.Thanks for all your help,it’s greatly appreciated,Michael
