- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
- Denunciar conteúdo inapropriado
Hi
My TV randomly turns off, goes to standby, since latest firmware update 3.925
It always seems to be on HDMI 1, the resolution on screen shows as 3840x2860p when switching on the connected device
So far I tested with PS4 Pro and Xbox One X and get the same results
Tried 3 different HDMI cables, factory reset and several soft resets haven't resolved the issue so far
I also have a Bose sound touch 300 which is connected via HDMI 4/ARC and SKYQ to HDMI 2
I've now had the Xbox one X plugged into HDMI 3 and there's doesn't seem to be any issue with the TV switching off
Really don't know what the problem is so hoping someone else has seen something similar and knows a solution?
Cheers
Edit: after a few more tests the issue appears to be happening on HDMI 3 now too
Solucionado! Ir para a Solução.
Soluções aceites
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I'm guessing people haven't come across this issue but I found the solution incase anyone else ever looks for it.
The issue was caused by the Bose sound touch 300. By default it's set to power off after 20 minutes if there is no audio recieved (I often use headphones for playing Xbox) so that's the reason the TV kept switching off. I changed the power setting on the soundbar via the app and now all is well
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Also to add all the eco mode settings have been turned off
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
