Series recordings fail on XR55A80J
CinnamonJalapeno
Member
I have a USB hard drive plugged in to my XR55A80J for recording programmes on FreeSat. I set a recording up as being for the whole series by going to the programme guide, selecting the programme, choosing Record and selecting the option for the series.
The first episode records correctly. However, subsequent episodes in the series fail to record. In the Timer List, the title for subsequent episodes gets replaces with "Searching for next episode" and the date is shown as a non-existent date (Sat 2 Jan, whereas 2nd Jan was a Sunday).
Anyone else had this? Is there a fix for it?
25 REPLIES 25
Anonymous
Not applicable
Or, you could just help the man, you know!
But, am glad he was able to find a workaround though by relying on that Humax recorder.
angelacr
Member
@Anonymous The problem with open-ended questions is, whilst wishing to be helpful, one  has no idea of the starting level of the person asking the question.  Self help, and if needed, follow-up questions from a position of some awareness, really is the only way to deal with the complexity of t'internet. IMHO
Anonymous
Not applicable
I mean sure, but you can also lead him on where to look exactly as a starting point, and not just Google, as this is a very general answer.
angelacr
Member
No. Google search is the way to go. There is no one website.
However I see your handle contains 404. That number signals a 'not found error' in http(s) responses, so maybe you're trying to tell us something?
HannahEd01
Community Team
Hey CinnamonJalapeno, I've contacted Sony to check and they said recording FreeSat is possible but not through the app. So which one are you using?
CinnamonJalapeno
Member
I’m not using any downloaded apps for recording, just the built-in native Sony functionality accessed from the Guide, as per the Sony User Manual.
M1ck-65
Member
Where is the Freesat app, I cannot find it on the TV and the play store says it's not available for this TV.
Yet it states on Sony's own help pages that the a80j is compatible with the Freesat app.
https://www.sony.co.uk/electronics/support/articles/00183238
So what is going on.
E61DRC
Member
I have tried recording using the terrestrial tuner (Freeview) and get the same problem with series recordings.
CinnamonJalapeno
Member
Remarkable. It really is beginning to look like Sony didn't actually test their software to see if it did what it is supposed to do.
HannahEd01
Community Team
Hi guys, i think that it works only through the built in SAT not the app as it's working just fine here on my device.https://www.sony.co.uk/electronics/support/articles/00183238
@M1ck-65 i found this article on their website that you might wanna check, it has the compatible models for the app: https://www.sony.co.uk/electronics/support/articles/00183238
i have the x85J with the software package version 6.4314, you guys might wanna check that you are on the latest software version.
