Setting up recording
Cleggs63
New
Bought new kid-xe8005 for mother in law. Trying to install external drive via USB port but option to set up does not seem to be as on line - reference is systems settings but only have settings on home menu.
1 REPLY 1
EdwinaU
Moderator
Hi Cleggs,
Thanks for joining the community.
I've found this help page on using your TV with other devices that might be of use. You'll also find the manuals and support contacts for your TV here.
Best wishes,
EdwinaU
