SONY BRAVIA KDL-40EX653
saranamjoo
Why am I unable to accesses YouTube on my TV?
5 ANTWORTEN 5
Anonymous
Nicht anwendbar
Hi there,
I'll check into this for you you and get back to you.
Welcome to our forums. :slight_smile:
Best wishes,
M
Drewde
Administrator
Hi,
Can you please give us a bit more info on the problem. Was it working before? Do you see any errors?
Thanks,
Drew
saranamjoo
Hello
Yes it was working before but after we upgraded the TV it didn't work anymore. The massage that the TV gives is that it's not responding.
Sent from my iPhone
Drewde
Administrator
Are you able to perform a factory reset to see if that fixes the issue?
Thanks,
Drew
saranamjoo
Hello
Not really are you able to tell me how to do it?
Thanks
Sent from my iPhone
