Hi,
I bought a new TV, X950H and when I turn ON and OFF the TV a ‘click’ sound is hearing from the back of the TV, sound like you are turning on/off a PC.
Is that usual for latest Sony TV’s? Because I have an old one and no sound is present.
I had also Samsung TV's and no sound was present when turning ON and OFF the TV.
Thank you.
Solved! Go to Solution.
Hi there,
This is the LED panel turning ON and OFF.
No need to be worried!
Have a great day!
No one has the same issue? It is a hardware problem?
I think this is normal, according to Sony:
https://www.sony.co.uk/electronics/support/televisions-projectors/articles/00090112
THANK YOU
Thanks a lot for the clarification, it's really helpful.
It'd be really helpful if you mark the thread as solved so that others with the same question can find their answer easily ^^
