VESA Mounts - Sony KD-49XD8305
greggwallace
Hello
Can you tell me how a tilt and swivel mount would work?
I cannot specifically find a 200x300mm mount. What size mount do I need?
Has the headphone bluetooth problem been sorted out yet?
Thanks all!!
1 ANTWORT 1
Anonymous
Nicht anwendbar
Hi there
Tilt and Swivel - TV can tilt up and down, and then swivel left/right.
A quick search on Amazon brings up:
https://www.amazon.co.uk/Masione-Articulating-TV-Mount-Bracket/dp/B019VXAKPG/
They are around, just look.
Sony recommends its own bracket - which tilts upto 20 degrees:
https://www.sony.co.uk/support/en/product/SU-WL450
Cheers
