HXR-NX80 camcorder not works with lamp HVL-LBPC
SOLVED
AndriusR
Explorer
Hi everyone,
I'm trying to mount lamp to my camcorder, but there is a message: "This accesory is not supported by the the device and cannot be used. Please verify the compatibility with the device".  What is the problem? Should i set something in Settings in camera?
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.IT.title
Marino.Manolo
In Sorry but...
I think (maybe) because the XML Inputs are too near in NX80.
5 REPLIES 5
Marino.Manolo
In Sorry but...
AndriusR
Explorer
Thank you Bro! Can you send me link where you found it, please?
Marino.Manolo
Of course, but you have to translate from japanese...:
https://www.sony.jp/nxcam/products/HXR-NX80/feature_1.html
AndriusR
Explorer
Thanks :wink:
Marino.Manolo
And of what? I had fun looking for this info... 🤗
