SONY DSC HX400v Power Supply
TPatel786
Hi all,
I have just purchased a Sony DSC HX400v after having used a HX300. I used to charge the HX300 and use it to take vides at the same time, however, i cant seem to do the same with the HX400v.
Is there a special adapter to use? if so can anyone help me with where to buy it?
Thanks in advance :slight_smile:
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
Nobody-in-particular
Vielschreiber
Hello and welcome.
On checking the user guide it would appear that using either the AC-UD10 or AC-UD11 Adaptor could allow you to shoot or review photos when connected to AC power.
4 ANTWORTEN 4
Vielschreiber
Hello and welcome.
TPatel786
Thank you for the quick response! Will have to order one now :slight_smile:
Vielschreiber
You are most welcome TPatel786.
macman2905
I often carry a portable USB Power supply and keep the USB cable plugged into the charging port, whilst taking photos and video. Works well if you don't get tanged up in the cables!
