Hi, Can anyone tell me what the Info button does in Xperia Contacts? I toggle it on and off and it doesn't seem to do anything. Can't find any post or manual entries about this. Thanks.
Gelöst! Gehe zu Lösung.
it will show you all the info that you have on a particular contact, if you sync facebook contacts it should show you their email, birthday, etc whatever they share on facebook
Don't forget to give Kudos
Many thanks. Makes sense now. I'll have a play with it and see if I can make it display more info.
