- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have a sony giga juke. It will not turn on using the remote - it is showing a blue flashing light as if it is in standby but the controls on the unit or the remote will not work. This happended before and I had to turn it off at the mains. Has anyone had this problem.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
specialist-convergence wrote:
To be honest we should have been more active on this, if only to let you know that we have been looking into it
We had already posted in this thread that Sony was aware of the issue & that it was being investigated
Thalamus. wrote:
Hi All,
just to let you know that Sony are aware of this problem & have been made aware of your comments..
Here is a response that we have received..
This issue is currently under investigation, unfortunately none of these products have had any updates or software related changes that could have caused this issue, we believe a service that is accessed by the Giga Juke has changed, although nothing has been advised, we will update the forum and the Service Network as soon as we find the fault and the possible cure, either by Sony or the 3rd party service.As soon as we hear anything more we'll update you ASAP..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I too have a Giga Juke and for the last ten months from new it has been working fine no problems what so ever. Two days ago I came turn turn the unit off and all I got was the blue "exploding" scene, it had locked up. The only way I could turn it off was through a "re-set". It came back on fine and then froze again I had to re-set once again. This is now the only way I can turn the unit off.
I am not able to get into any settings scenes
Is this the same problem as the rest of this thread? Is there a fix on its way? Any help out there?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi all
Some movement here at last but I don't have 'import from PC' or 'basic settings' on my gigajuke.
The top of my settings list is 'network settings'!
Any ideas?........
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Dear All
Can I just say a big thank you to Specialist- Convergence for this fix, throughout today he has been in contact with me beta testing this fix and has been very patient as I am no techno expert and probably slowed him down a little.
I have been able to turn on and off my unit some 20 times to day without the need to go through the reset .
I am very grateful for this temp fix and to that end I once again offer my thanks and as I said earlier in this thread have faith in Sony and there team they do get it right most of the time.
Well done
Simon
Message was edited by: blaireau_photo
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
OK IF YOU CUSRE DOWN YOU WILL FIND BASIC SETTINGS HOWEVER :-
USING GIGAJUKE MANUAL GO TO PAGE 86 AND FOLLOW INTRUCTIONS FOR TURNING OFF THE AUTO-SYNC UP DATE FEATURE.
WHERE IS SAYS GO TO PAGE 100 OF YOUR MANUAL GO TO PAGE 76 OF YOUR MANUAL
SELECT SOFTWARE UPDATE STRAIGHT FORWARD
PRESS HOME BUTTON STRAIGHT FORWARD
SELECT HDD JUKEBOX STRAIGHT FORWARD
SELECT SOFTWARE UPDATE IS STRAIGHT FORWARD
PRESS HOME SRTAIGHT FORWARD
IT DOES WORK I AM CONSTANTLY WALKING UPTO MY UNIT AND TURNINNING IT ON AND OFF - ALSO TRYING TO FOLL IT BY LOADING UNLISTED TRACKS AND THEN USING THE GRACENOTE FUNCTIONS AS PER PAGE 84 OF THE GB MANUAL.
WELL DONE SPEC !!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
WHEN YOU DO A RESET CAN YOU THEN TURN IT ON SO IT PLAYS MUSIC ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for your reply. But, if I curse down I don't find 'basic settings'. I've had it long enough to know that I've never seen the top two slections above 'network settings'. Exactly as it's shown on page 19 of the manual.
And yes, it does play music after it's been reset...But its now a standalone music player, not connected to anything (wireless receivers or router)
Message was edited by: HDFatboy96
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Well, the temp fix seems to work for me. Thanks. Apart from turning off the Auto Clock setting I cannot see this fix affects anything else, is that why it is a temp fix?
BTW, the instructions for the fix is clearly model dependant. Like HDFatboy96, I too do not have 'basic settings', or a couple of other headings as shown. Managed to work it out though.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hoping to have time to try it later just hope that it gets the internet connection back as hubby getting more and more wound up LOL
Fingers xxxxxxxxxx
May be back later if I have any probs as have already worked out that it is model dependant.
If everyone that tries the fix can post their experiences then we can get an idea of how good the patch fix is ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes, I definately have my internet connection back, and have been able to turn it on from standby repeatedly since applying the fix. All looks good so far.
Sony should now confirm what the problem was, if the problem still exists and could therefore happen again, and why this is only a temporary fix.
