SAWMT500 subwoofer has stopped connecting to the HTMT500 soundbar
slw986
Hi, my subwoofer has stopped connecting to the sound bar. The subwoofer now has a red light showing.
I've already tried relinking it, turning it off, but it won't reconnect. The sound bar is working fine though - thank you for your help in advance!
Sarah
1 ANTWORT 1
HannahEd01
Community Team
Hey Sarah, did you try resetting before relinking? If yes, I'm sorry to tell you that it will need repair.
