Blu-ray player
skinnjes
Blu-ray player
The blue ray laser on this unit has gone and will probably cost quite a lot to repair.
It plays CD’s and DVD’s perfectly.
Would it be possible to just buy a Sony Blueray player for around £80 and plug that in either to the back of the player or directly into the Sony TV?
1 ANTWORT 1
royabrown2
Forenjunkie
@skinnjes
Almost certainly yes, but do you realise you haven’t specified the make and model of the device on which the blue laser has gone, nor the model name of your Sony TV?
To give you a better answer, we need to know these things 😢
My favourite bedtime reading is a Sony product manual…
