ozzieofulceby
Explorer
DAV F200
Hi, can anyone help.
I have had the brilliant Sony DAV F200  Home Theatre System for a number of years now, in fact since it first came out.
About a month ago I seem to have lost the front panel display. When I power it up the only thing that lights up is the Sony name.
It woks fine, ie volume etc, just no display showing. I have tried disconnecting from the mains and reconnecting it, still no disply.
Any help would be much appreciated.
Mike
6 REPLIES 6
Pascale_F
Moderator
Hi Ozzie,
Welcome to the community.
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
Vanilla_
Contributor
Hi ozzieofulceby,
It's weird that it still can display SONY on startup. Have you tried to check the Display mode from the System menu? It should be set to "Standard". I'd also think of power cycling the system and see if this works.
Vanilla_
ozzieofulceby
Explorer
Hi Vanilla,
Thanks for the reply. I'll try again but have tried the power off power on a couple of times. Always worth trying again, maybe third time lucky.
Mike
ozzieofulceby
Explorer
Hi Vanilla,
Tried the Power Recycle, no joy and can not access the System Menu because I have no display on the front panel.
Just thought I'd let you know.
Regards Mike
ozzieofulceby
Explorer
Hi Pascale_F,
Tried what was suggested but to no avail I'm afraid so so still got the same problem.
Regards, Mike
Vanilla_
Contributor
Hello ozzieofulceby,
At this point, It's best to get the system inspected and repaired. I believe you can get in touch with one of Sony service centres directly using their website: https://www.sony.co.uk/electronics/support
Vanilla_
