Firmware Update 1.70 - Is it safe to upgrade to?
timauluck
Dear Forum Users,
I have an RDR-HXD870 that is on firmware version 1.65 and want to know whether it is safe to upgrade to firmware version 1.70, I have read numerous threads on this forum with users describing problems with firmware version 1.70 and very nervous with performing the operation just in case it causes more problems than its worth. I have read what fixes this firmware version and believe that some of the problems described in the firmware description are related to my problems.
Many thanks,
Timbuctoo
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
Anonymous
Nicht anwendbar
Hi there
Normally firmware updates are a good idea and fixes issues.  Considering that this update has been available for quite sometime, this would indicate that its entirely safe (if not, im sure it would have been 'pulled' long ago.
Just ensure that you follow the instructions exactly.
Cheers
2 ANTWORTEN 2
Anonymous
Nicht anwendbar
Hi there
Cheers
timauluck
Hi Quinnicus,
Thank you for your response and I'll follow the instructions to the tee.
Thanks,
Timbuctoo
