RDR PROBLEM SOLUTION
MandHNo10
Explorer
Try this:
Power off at mains
Wait 2 mins
Power on
Select system menu
Easy Setup
language Francais
country France
run auto scan
DON'T WORRY IT WILL FIND ALL ENGLISH CHANNELS
When scan complete exit back to TV
All UK digital channels will be there.
YOU CANNOT USE EPG
Select channels using channel up/down button on handset
You can view already recorded items via title list
You can record using record button on hand set and stop using stoprec utton
You cannot do auto record because no EPG
HOPE THIS HELPS UNTIL SONY COME BACK FROM THEIR LONG WEEKEND!!!
4 REPLIES 4
pewrigh38
Member
quickly tap the power button when its off, no need to wait for 2 mins
select ENGLISH for the language, but FRANCE for the location. this keeps the menus in english
profile.country.en_GB.title
gerry1047
Member
This is not a solution!
I use the recorder to set up future recordings. If I'm there to activate record....I could watch the prgramme live!
The real and unforgiveable scandal is
WHERE ARE SONY...NOT A WORD OF EXPLANATION OR APOLOGY.
THEY CLEARLY DONT CARE IN THE SLIGHTEST
butterfly33
Explorer
Thanks will try that. I wonder how many people have bought a new recorder thinking theirs was broken. Currys is open all weekend unlike Sony!!
butterfly33
Explorer
You can actually record advance programmes manually by setting the times and channel if you can be bothered. Let's hope the problem is sorted soon.
