The receivers standby modes are all switched off.
The TV's HDMI sync features are switched off as I don't want the receiver auto switching on every time I watch TV. Firmware is up to date on both units.
The issue I'm having is, when the TV is turned on from standby the receiver makes a loud clunk noise. This also happens when turning the receiver on/off.
Can anyone tell me if I have a faulty unit? Or if there's a way to stop this?
I have a double outlet socket for TV and Amp.
Trying to get past the robot on chat is very frustrating 😆
@mpezzer Try the steps here and test again: https://helpguide.sony.net/ha/strtaan10/v1/en/contents/TP1000544677.html?search
Hi and thank you for this,
Looks like there are some HDMI settings I need to change.
Have you been back to the retailer and asked them if it is supposed to make a loud 'clunk' when it is switched on.
Quite often amplifiers and receivers make a noticeable click, clunk or thump as the contacters are activated.
It may be perfectly normal for this model to clunk as it is switched on.
As for your TVs Bravia Sync settings you should have Audio system prioritisation in your Display and Sound> Audio Output settings.
If this is set to the Off position your receiver will not switch on automatically when you switch your TV on.
Hi and thank you for your response.
I Bought the receiver directly from Sony, that is why I'm here looking for answers, as I can't get any technical help from Sony.
I'm aware of clunks and clicks when switching on a receiver. I'm just not used to having a receiver clunk and click when switching on a TV that's connected to the receiver.
As for the Bravia sync, I don't want the receiver to switch on every time I turn on the TV. Watching the news channel in 5.1 does not appeal to me.
Again thank you for your response
