Lolo56620
New
Sony xperia L3
Quand je prend une photo elle ne s'affiche pas dans l'album ça affiche une photo noire avec le logo de l'album pourtant elle s'affiche en bas à droite dans l'appareil photo
Auriez-vous une solution à ce problème ?
2 REPLIES 2
Sean_Mc
Moderator
Hi there,
Welcome to the Sony Community.
I'd recommend getting in touch with the Sony Mobile support team here for further help.
Uliwooly
@Lolo56620
Try this
1. settings > apps > album > storage > clear data > back > back > camera > storage > clear data > restart the phone > check again
2. if you are saving the pictures on an SD card, unmount the SD card (settings > storage > unmount) > test the SD card with a different phone, to verify if the files are corrupted
2a. if they aren't then it could be an issue with your phone > try 1. again
if
2b. then the files are corrupted, there isn't much that you can do, you could try to restore them with RECUVA
3. for future reference, use a cloud based storage such as Google photos to autobackup all your pictures/videos whenever you are using wifi and/or charging your phone.
