Battery Issue
santosh9
Battery Issue
after replacement my xperia m i feeling again said bcoz its battery drain soon even just listening music and little watsapp.
sony say its 36hr music playback but i dont think so bcoz withing 30min its battery drain upto 20%.( just music without touch any app)
look withing 38 min its drain upto 59% without useing music just 3-4 time watssapp. Smirking_Face
and also i found new small fault its seen in screen shot.. network look full range its reliance sim.. and after lock screen its show insert sim.
and the camera also its not good its burnig in flash and noisey and pixelet the image with high yellow contrass.
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
Uliwooly
Your battery life its normal, normal in the sense on how you use your phone, check how long the screen has been on, wifi on, your network coverage its quite good. lower the brightness of the screen.
17 ANTWORTEN 17
Uliwooly
Could you upload the pictures on box.com and post the links here, as we can't see them?
santosh9
https://app.box.com/s/xf6hhfwtd9jlrzt9ua4i
look withing 38 min its drain upto 59% without useing music just 3-4 time watssapp. :smileyraised_eyebrow:
https://app.box.com/s/cw3owwygy6klrw4acp2q
https://app.box.com/s/lm74h6ragk9ce9dljcgb
Uliwooly
http://www.sonymobile.com/global-en/products/phones/xperia-m/specifications/
** Values are according to GSM Association Battery Life Measurement Technique as performed in controlled laboratory conditions. Actual time may vary.
There are myriad variants, like how long the screen is on, how good or bad the network coverage is there, etc, having whatsapp on, it will be using your data plan, thus draining your battery faster.
Uliwooly
You can read about the  GSM Association Battery Life Measurement Technique here
http://www.gsma.com/newsroom/wp-content/uploads/2013/09/TS.09-v7.6.pdf
santosh9
Realy sorry but i cant understand the properly what exactly it is... so can u expain me in short...
i just understand its depend on the network but sony say in 3G its 9hr talk time and 552 hr stand by / and 2G its 10hr talktime and 552hr something standby.. and alos i read so many reviews that say , they have good battery life even useing watsapp, music and browing upto full day ( meand 10 to 12hr).. and i see my cell its showing 43% now means whithin 4hr its drain upto 55% not useing any video player and game  just use of  music , watspp, and little bit browing. i just help me what can i do?
thanx for your reply uliwooly.
Uliwooly
Go to settings > power management > battery > take screenshots of
1) the whole list
2) tap on the graph > take a screenshot
3) back on the list, tap on each of the top 3 iems on the list, take a screenshot of each and post them here
screenshot = press and hold power & volume down at the same time
Uliwooly
