update problem*
rockyrocky
update problem*
Hai I'm in India and three days before I checked out my update centre and it showed 18.3.1.B.0.18 update availabile.. And my build number is 18.3.B.0.31 so I was happy and assumed that It might be 4.4.4 and so I started downloading it after some time I checked it out it said coul not download.. I tried to do that again and again but it kept on saying the same.and so I formated my entire mobile and then checked out the update centre and it showed nothing. I tried even using Sony pc suite it says ur phone has the latest available software.. But all I have is 4.4.2 with build number 18.3.B.0.31.. So I'm confused if the problem is in my mobile or just Sony cancelled the new update??
15 ANTWORTEN 15
Uliwooly
rockyrocky
Okay... I will just forget it!.. 😕
Uliwooly
Ok
Krish0117
Hi,
I also faced the issue in getting the new update. But after few attempts now I got the update and installed it also. But I m very disappointed wid dis update,bcoz after this update I m not able to use my official email in my phone. It always gives the error "not able to connect to server ". Can someone advise on this issue. Thanks
santhan1
Hi,
Sorry for my poor English.
im using Xperia m2 dual. In the previous week, I dad post some comments about the 4.4.4 kitakat update of xperi m2. I would like to list some problems that I have been facing since the update.
Lost note app
Lost small app sound recorder
Battery draining too quickly
Auto brightness not working properly
Nfc not working
Dual sim problems.
rockyrocky
Ya sure..
I too have problems with auto brightness
Yup have some battery draining problems too.
The only use of this update is my audio playback is good now..
