Hi All,
Just upgraded my XSola from .184 to 6.1.1.B.1.10 using SUES and now it is randomly rebooting like crazy. Sometime it will stay on for a couple of minutes but other times it just boot loop. BTW, I reinstalled the update + factory reset but problem persists.
Anyone having this issue ?
Solved! Go to Solution.
Anytime, I knew it (it was either the SIM or SD card)
unrelated topic, if you have some time please check this thread
remove the SIM and SD cards see if that does it
Hi Uli,
Thanks for your reply.
It seems that the problem is related to my Transcend 16GB SDCARD. I'm currently backing up my data and reformatting the card to see if it solve the problem.
which version you had used? India ? maybe you can try "global" FTF with Flashtool,it's worked fine with my phone.
Unfortunately, reformatting the SDCARD does not solve the problems.
Thanks Anyway.
Thank you for your suggestion, but I've already revert back to .184. I'll wait for JB and hopefully it won't be long.
sorry to hear that, you will need a new SD card in that case
I have this problem as well. I've tried several sd cards, ranging from 2gb - 32gb, sandisk and samsung.
The odd part is that this only happens on ICS. On GB, not a single problem.
On my samsung class 10 32gb sd I get bootloops, on my 2gb - 32gb sandisk cards I get random reboots when I try to copy files or play music/video off of it.
Very annoying. Not sure if I should send my device back for repair.
I've tested these cards on my old HTC Desire C and they all seem to work
I have this trouble too, somebody know how to fix it????? ((
