Hi All,
Just upgraded my XSola from .184 to 6.1.1.B.1.10 using SUES and now it is randomly rebooting like crazy. Sometime it will stay on for a couple of minutes but other times it just boot loop. BTW, I reinstalled the update + factory reset but problem persists.
Anyone having this issue ?
Solved! Go to Solution.
Copied from "the" another thread...
http://talk.sonymobile.com/message/322233#322233
Format it under FAT32 Filesystem of your microSD cards!
*and mark answers Correct or Helpful!
Regards,
Trubo
Upgraded to 6.1.1.B.1.54, still having the same problems. Back to .184.
just chiming in : I have this problem too, using a 32GB samsung sd-card. Luckily it's not a boot-loop, so the phone is usable, but especially when playing music (from the sd-card) it will reboot on average once every hour.
