Hi, I updated my xperia u to ICS (6.1.1b1.10) and sudenly I couldn't browse more than 1-2 minutes with wi-fi. I changed my rooter to 11 b/g mix instead of previously 11 b/g/n and it's working fine for me now.
My question is, is there any fix for this, cause i can change only my rooter settings, not public ones :smileywink:... and does 6.1.1b1.54 update fix wifi problem cause this update isn't avaiable for me in this moment (Macedonia). If so, how can I update to b.1.54 (latest version of SUS and companion says that b1.10 is the latest update as i mentoned before).
Thanks in advanse.
Solved! Go to Solution.
Possibly this is fixed
You can flash the latest firmware.
If you got time then please visit here:::::::::::::::::
TOP APPS for XPU::::
http://talk.sonymobile.com/thread/58158?tstart=0
Latest firmware ICS here and the guide to install it
http://forum.xda-developers.com/showpost.php?p=35339192&postcount=173
Custom Roms::
http://talk.sonymobile.com/thread/56689?tstart=0
If you are rooted then please visit
http://talk.sonymobile.com/thread/56641?tstart=0
http://talk.sonymobile.com/thread/56642?tstart=0
If you want to root:
http://forum.xda-developers.com/showthread.php?t=1886460
Please Mark
Custom Roms::
Please Mark
Thanks man... flashed newest firmwire (6.1.1.c.1.0) and it fix my problem... now i'm really happy with my phone.
If someone need further explanation about this (newbie like me :smileygrin: )... I followed this thread http://forum.xda-developers.com/showpost.php?p=35339192&postcount=173
Installed flashtool first, and tried to flash but it was asking for drivers... So, i installed them, turn the phone of... pressed volume down button and than connected the phone to PC while keep pressing the volume down button for a few more seconds. I did this just to make sure my PC install the device drivers (and it did it).
Then I disconected the phone and keep following the guide (step 2,3 and 4).
Thanks to jatinrungta for, making it posible to me to have nice phone again
Glad you could do it.
