Applications not uninstalling after clearing internal storage..!!
SOLVED
Adadvait
Visitor
I'm a new android user. Currently purchased  Xperia Go and its fantastic.I'm loving android.Upgraded my OS to ICS 4.0.4.
After tht i cleared internal storage(i dont know why i cleared it...damn me n my mistakes) and then I unnistalled some apps from manage applications(settings).But these applications remained on the menu screen in grey icons and again while uninstalling them android gives this error-'Application not found.The application was not found in the list of installed applications'.
I dont know wht's happening n this problem is really creeping me out.My phone is just a week old.
And when i install the same application,it replaces the grey icon and the app works..but when i try to uninstall that app,it gives me the above error..
plzzz help..!!!
wht to do....!!
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
how did you cleared the storage?
also if you moved this apps to the internal storage, that's the reason the apps arent working, just re-install them
UNRELATED topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
1 REPLY 1
Uliwooly
